View Full Version : 52 champion rearend /replacement
52bad-stude
04-09-2005, 10:55 PM
i have a 52 stude champion with a locked up/froze up rearend it measures 56.5 hub to hub . anyone no of a modern (85 or newer )rearend that will fit close to the same size
BRUCESTUDE
04-10-2005, 12:27 AM
You can use a later Stude rear end, there are many ratios to choose from. Also the later V8's had better brakes. I changed out my '52 Commander's 4:55 to a later 3:54 ( I only use OD on the freeway now).
04-10-2005, 09:14 AM
It seems to me that I've read of guys using a Fairlane/Meteor rear with no more than moving the spring perches. Actualy, finding a replacement original rear shouldn't be too hard. What part of the country are you in[?] Maybe we can come up with a source close to you.[^]
04-10-2005, 07:49 PM
I was out back amidst my Stude stash awhile ago and I found a good rear axle out of a '52 Champion. It's got 4.56 gears, which is what they used with an OD 3-spd tranny. It's for sale. If you're in California, you could maybe drive here and claim it. If not, shipping would be a bear and I'm not up to prepping it and lugging it to a shipper.
52bad-stude
04-10-2005, 10:35 PM
thanks MRBIGGS but im from MO and im looking for something newer more modern and would like 5x4.5 bolt as well so i can use the org rims ....but thanks for the info
Transtar60
04-11-2005, 02:58 PM
You could always use a Dana 35C from a Jeep Cherokee.
dclewallen
04-11-2005, 05:07 PM
Check on a early 90's Ford Ranger 2-wheel drive rearend. It's an 8.8 with the same bolt pattern as the Stude wheels, plus it even looks like the Stude rear.
Darryl C. Lewallen
gotti210
04-11-2005, 05:40 PM
i know its the wrong pattern but an s-10 rearend fit perfectly in my 50 no need to change perches or anything its 54" hub to hub (i needed 2" extra space for bigger rims and tires
Also a ford maverick (same bolt circle as stud ) is 56" hub to hub
and looks to fit farly easily
good luck
Transtar60
04-11-2005, 07:14 PM
Good Luck is right, when was the last time you saw a Ford Maverick???
:D
gotti210
04-11-2005, 09:16 PM
i dont know off hand wheres hes at but the junkyards are full of em here in tx
52bad-stude
04-12-2005, 08:21 PM
thanks again for the replys . i have measured the s-10 and its 54.5 after measuring the car i have about 1" inboard and 2.5 outside but im holding out for the same size 56.5 i will be checking the boneyard for 90's rangers and mavericks and will measure all i can find
gotti210
04-13-2005, 12:20 AM
like i said ive been scowering the boneyards for something with a rearend narrow enough for months and mavericks ARE 56 maybe 56.5 not sure but i know they are in the 56's
hey good luck
