View Full Version : Detroit Gear Trans Fluid
Commander51
04-03-2005, 10:07 AM
Shop manual recommends 10 weight motor oil for DG-200 transmissions. What fluid do you run in your tranny--stick with the original, or 'upgrade' to modern fluid--if so, which type[?]
04-03-2005, 10:35 AM
Use Dexron-Mercon III Just be sure you drain the torque convertor when you drain the pan, so as to get ALL the old oil out.;)
Powered by vBulletin® Version 4.2.4 Beta 2 Copyright © 2019 vBulletin Solutions, Inc. All rights reserved.
