View Full Version : Front drive shaft flange
Tbatson
02-22-2005, 09:26 PM
I replaced the rear oil seal in the tail shaft of a 56 Champ 3 spd with OD. The front drive shaft flange came right out by taping with a hammer. It's a slight press fit and Studebaker states that I should use a J-2204-A Flange Pusher to get it back on the shaft. Now you know I don't have that tool!! Can I just square it up and hit it on with a hammer? Any thoughts/techniques will be appreciated.
Thanks, Tom
02-22-2005, 10:34 PM
"Flange" doesn't compute. Are we talking the "yoke" that the U-joint couples to? If so, yeah, use a piece of wood or a soft metal drift between the yoke and your hammer when you really whack it. At first, just align it as well and you can and lightly tap it a bit to get it started. ;)
