View Full Version : Jets and idle problem...
dan0
02-20-2005, 09:53 PM
Dudes-
How can I make my Commander 6 idle in damp weather? she stumbles/stalls when it's damp. When the wx is dry, perfect. Any ideas how to fix?
thanks
dan0
Stuff:
1941 M15...retirement project
1953 2R11... daily ride
2001 F-350 Super Duty Lariat to haul it all..
1989 Caprice Classic Brougham
Sexy! 67' John Deere 112H
N8N
02-20-2005, 10:08 PM
Tried new spark plug wires? I imagine that the metal shield used on that engine would make the engine fairly sensitive to wires with insulation that's starting to go...
good luck,
62 Daytona hardtop
studegary
02-21-2005, 03:10 PM
I agree with Nate. Clean the exterior of the spark plugs, clean the interior and exterior of the distributor cap and install new secondary wires.
dan0
02-21-2005, 10:20 PM
Ya but...
It idles/runs perfect in drier condtions. What gives?[:p]
Stuff:
Sonny
02-21-2005, 10:51 PM
quote:Originally posted by dan0
Ya but...
Stuff:
Just the moisture in the air will set up a conductor for a misfire where the wires are close to each other or anything metallic. Your wires have tiny cracks that you can't see, (or probably can't), as the outer casing insulating properties breaks down after a few years, especially from the heat.
Sonny
http://RacingStudebakers.com
Sam Roberts
02-22-2005, 08:11 AM
On a V-8 it is best to separate number 5, and number 7, wires in the loom. I use to get an annoying miss due to that until I put number 3 wire between them. Not being familiar with a 6, and the firing order, etc., but maybe there is something like that in them as well.
Sonny
[/quote]
Sam Roberts
02-22-2005, 01:51 PM
Moist air will also find it's way inside the distributor cap too. This can cause the same sorta grief. If this thing runs fine in dry weather, it's not the carb.;)
dan0
02-22-2005, 07:58 PM
I dunno dudes. It does not misfire. It just refuses to idle. Like it would rather flood out from being too rich. I'll ck the ign sys.
thanks
dan0:D
Stuff:
Sonny
02-22-2005, 10:33 PM
Have you ever drained and sealed the gas tank? Blown out all the lines from the tank forward, taken the carb off and checked to see if there's any crap in the bowl? I think everyone was going on your wet/dry weather comparisons. For a fuel situation, it's usually hot/cold weather that causes problems, wet or dry normally has no effect on fuel delivery, unless it's cold and wet.
It's hard to diagnose problems so far away and no hands on, always better when we're loaded down with as much information as you can provide so we can give you the most through answer.
Sonny
