brakes
  • brakes
    i have a single line master cylinder brake system in my car. i would like to install a double line system (one line for the front and one for the rear) i was wonder if any has done this conversion and what new master cylinder did you use, and how difficult it was, if at all. i have a 63 lark drum brakes all around.
    All '63 Larks with drum brakes had a dual master cylinder/split brake system from the factory, except for the very cheapest model(s). All that you need to do is use the parts from most any '63 Lark that has drum brakes and dual master cylinder. Use new, replacement parts for the master cylinder and lines.
