i wondering if anybody out there has a T-10 transmission for a 63' 6 cyl. or knows of any place that might have one. It can be used or nos. i've already tried a stude shop out in florida and looking for any other places.
transmition
Cosmo, no T-10s were ever used in Stude 6-cylinder cars. This is not to say that one couldn't be ADAPTED to work with a 6 but again, you're talking about as much work (engineering) as fitting a T-5 to it. Stude 6s came with an automatic or a 3spd / 3spdOD as far as cars went. You COULD get a truck 4-spd behind a 6 (in a truck only), but that's a massive, clunky tranny that wouldn't begin to fit in a car. And you wouldn't like the way it performed anyway. It was a heavy duty WORK unit - not a fun-shifting, performance piece.
Back to the T-10 (used behind Stude V-8s in cars), NOS - forget it. Used and not in need of an overhaul, figure $500-up. Then you'd hafta adapt it to the 6's bellhousing and clutch and also adapt the T-10's clutch linkage, assuming you'd gotten all that when you bought the tranny.
You COULD just buy a modern, aftermarket hydraulic clutch setup and adapt it to the T-10 but again, it's a matter of designing and making the necessary bits to fit the slave cylinder to the clutch linkage.
We're back to the 3spd/OD tranny being the best and easiest way to get more driveability out of that 6. Get the parts - bolt them on. And with a 3spd/OD tranny, you can drive it like a 5-spd.
Start in first, shift to second, then second OD, then third and then third OD. Count 'em Cosmo - five gears.
Of course, your car - your choice. There's nothing says you hafta take our advice.
Miscreant at large.No deceptive flags to prove I'm patriotic - no biblical BS to impress - just ME and Studebakers - as it should be.
