Yesterday, I was taking apart a '64 OHV six that had been out in the weather, and had the pistons seized in the block.
I took the rear main bearing cap off, and noticed some "stuff" packed in the groove where the oil slinger goes. At first, I thought some insect had built a nest in there. Closer examination revealed several filter-tip cigarettes carefully packed in there, end-to-end, and the same in the matching groove in the block. You could still smell the tobacco.
This engine was probably last apart in the late '70s or early '80s.
Anybody here ever hear of packing that groove with cigarettes in order to control rear main seal oil leaks?
One bonus: I got an aluminum timing gear out of it, so it was a good thing I decided to strip the block rather than scrap it intact.
