View Full Version : rear seals 51 champion
robert barker
02-27-2007, 04:37 PM
need help on how to replace outer grease seals and bearings on rear axle of 1951 champion coupe . any help would be good.please email info to Bob at barker@prtel.com
02-27-2007, 10:50 PM
Welcome to the SDC forum Bob, we are always glad to have new members or existing members who "find" the forum! [^]
The Bearing & seal replacement job will be a lot easier WITH the Studebaker Shop Manual available at many of the vendors at: studebakervendors.com
It should be a pretty straight forward R&R job though. If you have the correct parts & a proper drum puller. You will need 4 backing plate gaskets also. There is one on each side of the "stiffener" plate that goes between the backing plate & the outer Seal.
The bearing replacement does require a hydraulic press or a machine shop to do that job of R&R'ing the Bearing to the axle shaft. I would not do all of that work to pull the axles without changing the Inner Axle Seals also.
Studebakers Northwest
Ferndale, WA
