I have a 1950 Champion 4 door sedan, I took it to a shop to have an oil leak stopped. The found the Distributor was leaking through the vent hole on the lower side. They pulled the Distribtor and rebuilt it but every since the car will not shift up into cruise, Plus the car when you step down on the Excelorator it cuts out like the fuel pump is failing. It back fires and sputters but I have been lucky enough to nurse it back home from about five miles away.
Is it the Electrical or fuel Pump And would that have anything to do with the OD not shifting when it is in OD?
Thank You for your knowledge and replies.
Raymond F. Pittam
Raymond F. Pittam
