I recently changed the front drum brakes on my 64 Daytona to disc. . From the very beginning it has created problems. First I changed the master cylinder to a unit that replaced the old unit in the car, brakes to the floor. Next step, I changed the rear wheel cylinders and added a 10# residual valve to hold pressure, pedal still goes to floor, and only holds after pumping the mc. This is not a power assist brake system. What am I missing? Do I need a mc with more throw? If so which one should I use?
Brake conversion 64 Daytona
If you have no pedal you must still have air in the system somewhere, time to bleed brakes again.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
did you put in a preportioning valve in the rear line?
[IMG]
1960 Champ
1964 Daytona HT
1966 Daytonasigpic
Gorgeous car. Anthony; congrats!
My initial reaction is that you did not properly and thoroughly bench-bleed the new master cylinder before installing it. If that is not done correctly, you'll never "get" a pedal with the unit in the car. [8D]BPWe've got to quit saying, "How stupid can you be?" Too many people are taking it as a challenge.
Check the adjustment between the M/C and the linkage, if you have too much play, you'll have a low pedal and poor brakes"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
If running the stock single M/C, you'll need to defeat the built in residual check valve. If running a dual M/C, you'll need to cut the linkage a little bit short, drill & tap the end and use a button head allen to "fine tune" the adjustmant.
That's what I did on the 62 Daytona ragtop I sold.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
car came stock with a dual m/c. we changed it to an aftermarket one. did not have built in residual valves. i checked it. thats why we added a 10# inline to the rears. almost seems like the throw is wrong on the linkage. i know someone has run into this problem before. wish we could find a rebuild kit for the stock cyl, so i can eliminate the possibility of having the wrong cyl. rebleeding it helped some. but still going to floor. if you pump the brakes it will hold. but if you let it sit for a few seconds it looses pressure. thats what made me think residual valve. but after installing it and it not changing anything, i am thinking the rod to m/c isnt long enough to get a full stroke and not building up enough pressure to hold
OR... the master Cyl. piston is not returning all the way, blocking the "Bleed Port" and not allowing the air to bleed out! [:0]
StudeRichStudeRich
quote:Originally posted by struckinc
what would cause it to not open all the way? wrong cylinder for rod length? or it needs to be taken off and completely re-bled?
StudeRichStudeRich
Another possibility is you have some low friction calipers that need a 'quick take-up' master cylinder. There was something on the forum last summer about this...only applies to gm intermediate body calipers such as Turner conversion uses. Junior
54 Champ C5 Hamilton car.sigpic
1954 C5 Hamilton car.
