Hello all,
I started cutting out bad floor repair I did on my hardtop nearly 20 years ago to use a Classic floor that has a bit of surface rust. If I want to use por-15 to seal everything up, how clean do I need to get that floor panel? I know I need to grind where I will weld clean but how about everything else, I plan to run my big grinder with wire brush attachment over the panel to clean off some of the surface rust.
while I am at it, I have a few large pieces of 18 gauge steel around, did Studebaker use 18 or 16 gauge for the floors?
As far as my hardtop, I need to get the right door off and finish cutting and trimming before I can start patching and welding.
Jeff T.
"I'm getting nowhere as fast as I can"
The Replacements.
Jeff T.
The Replacements.
