The "Power Cylinder" (p/n 1551362) is leaking where the rod goes into the cylinder. SI sells a rebuild kit called the "Control valve seal kit" (p/n 1553403). The problem is that the PO welded the rod to the end assembly where the grease fitting is.
I think this renders the rebuild kit useless. Please help.
