ohm rating for 61 Hawk fuel sending unit.
  • ohm rating for 61 Hawk fuel sending unit.
    Can any one tell me the operating ohm range for the fuel tank sending unit in a 61 Hawk?
    Jon Kammer
    should be 0 ohm empty 90 ohm full
    Allan Tyler Melbourne Australia
      IF 12 volts, which a 61 should have, I believe the range is 233 ohms to 33 ohms.
      A 6 volt car would be close to the 0 to 100 ohms stated above. USE THE FORUM SEARCH
      function under "Fuel Gauge topic" .
      The 1950 Champion Starlight
      Santa Barbara
      CA
        When researching this earlier I found the following which lines up with the above answer:
        29.0-33.5 full,240-250 empty
