View Full Version : filter on top of the motor
studelover
02-24-2007, 01:04 AM
I have heard people here talk about full flow and patial flow. The 289 came with both these features? Does this have to do with the type of filtration or year model? Can one be converted to the other?
Studebakers forever!
JDP
02-24-2007, 01:40 AM
Late 1962 model year, the change was made to full flow, not possible to convert earlier to full flow without lots of engineering.
64 Commander 2 dr.
64 Daytona HT
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Daytona HT/ 4 speed
62 Lark 2 door
62 GT Hawk 4 speed
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
MagikDraggin
02-26-2007, 11:22 PM
You'll have to excuse the 'dummy' here for asking, but how does one determine which one they have?
Karl
http://img.photobucket.com/albums/v147/MagikDraggin/Other%20Stuff/62StudebakerGTHawk1-small.jpg
1962 GT Hawk 4sp
JDP
02-26-2007, 11:31 PM
If you have a spin on filter mounted under the right hand side of the engine, you have a full flow, mounted on the top front, partial flow.
64 Commander 2 dr.
64 Daytona HT
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
62 GT Hawk 4 speed
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
StudeDave57
filter on bottom- full flow :)
filter on top- probably not :(
StudeDave [8D]
V/P San Diego County SDC
San Diego, Ca
'54 Commander 4dr 'Ruby'
'57 Commander 2dr 'Baby'
'57 Champion 2dr 'Jewel'
'58 Packard sedan 'Cleo'
'65 Cruiser 'Sweet Pea'
studelover
02-27-2007, 06:20 AM
thanks for asking that question studedave, I really wanted to know however I was afraid to ask, thanks! you are no dummy. Some of us just don't know about these cars, our question may sound elementary. these guy have been around these cars ans have taken them apart , put them back together and driven them. They are very familiar with the technology, sometimes a little patience is required.They have me a little shell shocked right now.
DEEPNHOCK
02-27-2007, 07:19 AM
Back in the day... Filtering oil was an option.
Companies like Fram started out making accessory oil filter 'add on' kits. Then they started selling these kits to the auto makers and they started marketing this option as a long life option.
The difference between a 'partial flow' and a 'full flow' is fairly simple. A 'partial flow' oil filter is where oil is taken from a passage in the engine (usually one that is easily accessible) and run through the filter, and then dumped back into the oil pan through a return hose (that usually has a restricted fitting to keep oil pressure up). It only 'partially' filters the oil. Studebakers with the oil filter on top, and Champ 6's were a good example of this style. Whatever oil that went up the block into the head and into that line....got filtered. Something filtered is better than nothing filtered, but it was more of a visual reassurance thing than anything else.....
A 'Full Flow' system is different. It takes ALL the oil put out by the oil pump and filters it. The oil comes out of the oil pump, goes through the filter and right back into the main oil feed right above the oil pump. Much, much more efficient. All the engine manufacturers went to this system later on, Studebaker included. Studebaker did sort of a Band-Aid setup by externally plumbing the full flow filter lines (so they did not have to re-design the block casting), which worked well.
Still, nothing beats changing your oil on a regular basis.
Good question!
http://i77.photobucket.com/albums/j54/deepnhock/Jeff%20Rice%20Studebaker%20Pictures/1937StudebakerCoupeExpressJeffRicee.jpg
DEEPNHOCK at Gmail.com
Brooklet, Georgia
'61 Hawk (project)
Chucks Stude
02-27-2007, 10:07 AM
As far as engineering, back in the 70's, we used to convert blocks to full flow, mounting a 2qt spin on filter to the frame. The whole job was done with a 1/2 " drill, some 1/4" pipe, a small freeze plug, a tap, and a drill bit with three bits on the end, so that the drill would center itself in the hole. This was all done in a barn. No machine shop.
Transtar60
02-27-2007, 10:46 AM
Actually Jeff they DID redesign the blocks to intergrate the full flow systems. None of my full flow blocks have external oil lines(well except the one to the gauge). My 62 Champ came with a full flow block, but with a partial flow filter up top. It had a block off plate cover on the place where the full flow filter mount could have gone.
Good question!
Jeff[8D][/b]
Brooklet, Georgia
'61 Hawk (project)
http://community.webshots.com/user/deepnhock[/navy]
[/quote]
http://racingstudebakers.com/coppermine/albums/userpics/10056/5E13%20Pic%203.JPG
3E38
4E2
4E28
5E13
7E7
8E7
8E12
8E28
4E2
59 Lark
etc
02-28-2007, 02:57 AM
Actually Transtar60, Jeff did say they changed the block. I think you missed this part:
quote:[i]Originally posted by DEEPNHOCK All the engine manufacturers went to this system later on, Studebaker included.
In the later part that you do not agree with, I guess he was talking about the 1958 to early 1962 "spin-on" kind and calling it "full-flow" in error. (it is NOT !) Right, Jeff?
Studebakers Northwest
Ferndale, WA
DEEPNHOCK
02-28-2007, 07:53 AM
I'm not splittin' hairs with this group;)
A partial flow filter system is a partial flow system, whether it has a cannister type filter, a spin on filter, or a toilet paper filter[:0].....
I guess the real question is.. Do you filter ALL the oil, or just some of the oil....
