Am wanting to replace the standard column with an original tilt steering column in my '63 Avanti. Any advise or knowledge of one available out there would be appreciated. Thanks for looking.
Tilt steering column for Avanti
The "tilt wheel" was a '64 option, not offered in '63. According to George Kremm, Only 97 cars were equipped with them from the factory. I think a lot of them were on hand when Stude stopped production; and they were popular in Avanti II's.
The range of adjustment is mostly down, and unusable for most people.
The unit is similar to tilt wheels used in GM products from that time; particularly Olds. It works well, and is reliable; as is the special turn signal switch. It's just that the range of adjustment is inappropriate.
Mike M.
Paul Johnson, Wild and Wonderful West Virginia. '64 Daytona Wagonaire, '64 Daytona convertible, '53 Commander Starliner, Museum R-4 engine, '62 Gravely Model L, '72 Gravely Model 430
My father's 1964 Studebaker Avanti came factory equipped with tilt steering. Unfortunately the feature was missing when we purchased the car for restoration. How difficult is it to obtain an original tilt column or even the specific parts that Studebaker added? - (such as the Avanti spline piece - as I have seen in the parts manual, or the tilt switches).
Thanks,
Mitch
They are a Saginaw column, and were also used on GM products of the era. The one I restored had full range up and down. (3 up, centered, and 3 down).
I got the turn signal switch, and control cable from Impala Bobs'. I'm sure there are other classic chevy dealers like Danchucks that will also have them.
I had Y and Z yesteryear parts make a complete wiring harness for this car, and included the tilt harness from the signal switch to the stock harness plug. Brian was great to work with. I also provided the trunk harness, the harness to the taillights, the front headlight buckets, and also the turn signal. So the make everything, and it is correct.
Dave Tbow now sells Y and Z harnesses.Bez Auto Alchemy
