View Full Version : installing Silvertone dual exhaust
Kdancy
02-22-2007, 08:48 AM
I am installing these on the 63 cruiser. Body is off. How far down does the tailpipe drop from the rear frame cross member? I don't want to take a chance on the "over axle" bend of hitting the body when I put it back on.
They do look nice, just wish they were mandrel bent.
02-22-2007, 01:35 PM
Measuring from the top of the straight level portion of the tailpipe before the bend upward near the end, right above the rear spring eye there is 2 inches clearance to the frame, and that leaves 3/8 in. to the spring eye. Be sure that you angle the "over the axle" dip-up's inboard about 30 degrees for improved axle clearance, level tips and correct fit. Keep in mind that I only have original Studebaker pipes to check, no re-production stuff, so your results may vary! [^]
The ends of the tailpipe are supposed to be curved UP, then back down and cut level with the ground to send the exhaust out away from the bumper, down and be hidden above the bumper just like '62-'63 Dodges and all MoPar's were, and they really were practical and racy looking tucked above the bumper. There should be a tire casing rubber strap bolted to a bracket welded to the pipe right under the rearmost crossmember to secure the end. I've seen the 2 1/4 in. performance Silvertone exhausts on George Krem's "Brown Wrapper" '64 Challenger, and they do not look correct.
Are you saying that the bends are KINKED (convoluted)? And not mandrel bent, that's not going to work for judging! :(
Studebakers Northwest
Ferndale, WA
Kdancy
02-22-2007, 07:23 PM
Ferndale, WA
Thanks for the reply --
It is the typical muffler shop type bends. I do realize that mandrel bending presses are very expensive and the reason most don't have one. I could only find two shops in Fla that does mandrel bent exhaust when I had a set custom made for a customer's 69 Camaro. Expensive, but very nice with no restrictions. That too was an all stainless exhaust.
sbca96
02-25-2007, 06:49 PM
Just typical muffler shop bending? The exhaust I HAVE on my Avanti is
SOOOOOO poor that I have to make SURE that I dont get it again. My dad
described the Nostalgic exhaust bends, and I think thats what I have.
One of the over the axle pipes is kinked about 1/2 way through. Pretty
sad work. Its also very tiny. I was thinking of getting the 2-1/2
inch Silvertone, maybe that will make up for the crush and bend style
and not the mandrel bend style I want. I wish that Silvertone would
step up to the plate and make the change. If someone wants OEM they
can get the Nostalgic, stainless steel is already not "correct".
Tom
