Hi guys, a friend in our Chapter (Bill) has a nice frame-on restored '55 President State long wheelbase Sedan, and he got the GM Trans adapter from Jon Myer and is having his Brother Dan who has built several street rods, install a GM 700R4 Overdrive onto the Stude. 259.
He needs help figuring out how to best connect the:
(1) Speedometer cable, adapter gearbox available?
(2) Shift linkage, has anyone used the stock Stude. Column shifter?
Or just used a Lokar or other floorshifter unit?
(3) Throttle pressure linkage.
Can the Stude. throttle Press. bellcrank lever be used?
Or a Lokar cable to Carb.?
(4) Two piece driveline with slip joint to a slip yoke GM Tranny.
Will a custom driveline shop front shaft work, with [u]TWO</u> slip-joints?
I told him I am the wrong guy to ask, as most of you know... I would leave the factory engineered stuff alone!
Can some of you "Stude. Rodders" help him out please? He is pretty much a Chevy guy
so knows his way around these Transmissions.
