View Full Version : need help with wiring
studehunter
04-10-2010, 10:07 PM
After 6 years of work i have the wiring finished in my 54 coupe but can not get the starter to power up. the problem is the wiring of the saftey neutral switch. can someone help me with the correct wiring of the safety neutral switch? Thanks
Domenic Manera
1954 Regal Starlight Coupe
tbredehoft
04-10-2010, 10:59 PM
100 '54? Automatic? Commander or Champion?
110 If it's a Champion, goto 130
120 If it's a Commander, goto 140
130 there's a wire to the button on the dashboard that goes to a plug on the steering column just inside the engine compartment. Goto 150
140 the switch to the left of the key has a wire going to the plug on the steering column just inside the engine compartment.
150 A wire from the other plug terminal there goes to the S terminal (the small terminal) on the solenoid.
160 Put the gear selector in P, turn the key on and push the button.
170 End
Tom Bredehoft
....On the road, again....
'05 Legacy Ltd Wagon
All Indiana built cars
studehunter
04-10-2010, 11:29 PM
Tom thanks for your help, it is a commander and all I need help with is the wiring of the safety neutral switch. Everyhting else appears to be correct
Domenic Manera
04-11-2010, 04:56 PM
quote:Originally posted by studehunter
/Cut/all I need help with is the wiring of the safety neutral switch./Cut/
Tom's line 140 & 150 wires a Commander Neutral Switch, on the Steering column, engine side of the firewall. [:0]
Sdude
04-11-2010, 07:56 PM
Sorry, I'm no help.
http://farm3.static.flickr.com/2782/4438957636_63f4a82923_m.jpg
Looks like somebody lost their spaghetti dinner to me...[xx(]
Jon Stalnaker
Editor, Hawk Talks
Karel Staple Chapter SDC
http://farm4.static.flickr.com/3108/2848527836_6f817c03fc_s.jpghttp://farm3.static.flickr.com/2760/4501404372_a359aedb6e_s.jpg
Flashback
04-11-2010, 08:03 PM
My goodness Jon, am I missing some wires? My whole harness is shown here?
Can't help on the safety neut. Mine's a 3 pedal car.
http://i307.photobucket.com/albums/nn320/Flashback53/thanksgiving017.jpg
Tex in Alabama
http://i307.photobucket.com/albums/nn320/Flashback53/thanksgiving016.jpg http://i307.photobucket.com/albums/nn320/Flashback53/thanksgiving014.jpg
Makin' a little progress
Sdude
04-11-2010, 08:13 PM
I added a couple of upgrades [:p]
Jon Stalnaker
Editor, Hawk Talks
studeclunker
04-11-2010, 11:57 PM
Really Tom![V] Didn't you know that 'goto' statements in programming are poor code?:( And where [u]is </u> your documentation?? I'm simply going to have to report you to the System Administrator![:o)][:o)][:o)]
You know, I've been saying for years that we need a raspberrys Smilie.;) You know, whomever came up with that switch did something right for once. I found out the hard way that they really are necessary. Suffice it to say, Nana was lucky to make it another four years. I sure am going to miss my cuddly co-pilot.:(
http://i16.photobucket.com/albums/b18/Studeclunker/december%2006/HPIM0234.jpg http://i16.photobucket.com/albums/b18/Studeclunker/56%20Parkview%20Wagon/56wagonleftfrontclipped-1.jpg
Home of the famous Mr. Ed!
Ron Smith
bams50
04-12-2010, 05:16 AM
quote:Originally posted by studeclunker
[font=Comic Sans MS][size=3]You know, I've been saying for years that we need a raspberrys Smilie.
Here ya go, Ron: http://www.mysmiley.net/imgs/smile/tongue/tongue0001.gif
Or maybe:http://www.mysmiley.net/imgs/smile/tongue/tongue0011.gif
Or: http://www.mysmiley.net/imgs/smile/tongue/tongue0020.gif
Parish, central NY 13131
http://www.patrioticon.org/images/flag1-1.gif
tbredehoft
04-12-2010, 07:25 AM
Sorry, Ron, when I was doing code, 30 years ago it was all the rage. Subsequently I spent 15 years with a machine code (for operating CNC machines) it was all numbers. G01, G30, etc. No human logic to it at all.
Tom Bredehoft
Dwain G.
04-12-2010, 04:38 PM
Use the two push-in terminals at the cut-out switch.The two screw terminals are for the back-up lights.
In this system, the small terminal of the solenoid is grounded to energize the starter. You can connect a jumper wire from ground to each terminal (solenoid, cut-out, dash switch) to isolate the problem.
http://i242.photobucket.com/albums/ff195/DwainG/IMG_0097-2.jpg
