Well I had to put a new line on the front and got a spool of rust resistant Nickle zink tubing and a flare tool and will replace all the lines. I could not get a stream of fluid to bleed out just some tiny bubbles. But it will stop you have to pump once and on the second pump the rears will lock up if your not careful. The MC is leaking from under the boot up front. I will get a new MC for it run new lines, have the HV rebuilt. I think a SDC member is rebuilding them for under a $100.00 [img][/img][img][/img]
Does anybody know if wheel cylinders are still availible for the Toters I think it's. Ton and a half.
John
62' Deluxe R2 4SPD.
63' R1 Wagonaire
58' 3E6D Stock
John
62' Deluxe R2 4SPD.
63' R1 Wagonaire
58' 3E6D Stock
