View Full Version : Address of Truck Plant
ST2DE5
03-26-2010, 10:52 AM
I would like to know the address of the new SI in the old truck plant at South Bend.
http://ozarktrails.tripod.com/
Studebaker Diners Club
tbredehoft
03-26-2010, 11:29 AM
Yes, so it can be put into GPS devices for finding SI West.
Tom Bredehoft
....On the road, again....
'05 Legacy Ltd Wagon
All Indiana built cars
Retired
03-26-2010, 01:48 PM
Enter; Studebaker Industrial Park, Chippawa Ave. South Bend, Indiana
Richard
tbredehoft
03-28-2010, 01:51 PM
Can some native of South Bend advise on the correctness of the following statement?
To go from the St. Joseph Co. Fair Grounds (the Swap meet) to the new SI building one exits the fair grounds on the north side (Johnson St?) and drives west to US 31 (Michigan St), drives north under Rt 20 to Chippewa Ave (two blocks) and turns west to the new facility?
This is taken from MapQuest, I'm not at all sure it's right.
Tom Bredehoft
Chris_Dresbach
03-28-2010, 06:13 PM
Tom Bredehoft
From the fair grounds: exit at the north exit (Jackson Rd.) and turn right until you get to the intersection (Inronwood Rd.) go left. Keep going straight until the next intersection (Ireland Rd.) turn left. Keep going that way until you get to S. Michigan St. and turn right. Go straight until you get to Chippewa and turn left. Drive straight until you see the big lazy S sign that says "Studebaker Business Corp." and turn there, it will be on the right.
Chris Dresbach
http://i768.photobucket.com/albums/xx323/chris_dresbach/Studebaker%201/ModelN-1-1.jpghttp://i768.photobucket.com/albums/xx323/chris_dresbach/40champion-1-1.jpghttp://i768.photobucket.com/albums/xx323/chris_dresbach/Studebaker%201/N10-1-1.jpg
1940 Champion two door.
Parts of the 1952 Model N
1960s Prototype cart
Chris_Dresbach
03-28-2010, 06:16 PM
Plant 3 & 4, or Aviation plant, then trucks.:D[:o)];)[8D]
Chris Dresbach
ST2DE5
03-28-2010, 06:34 PM
Thanks Chris. There for a while I thought it was top secret. I know exactly where it is at now.
Chris_Dresbach
03-28-2010, 07:02 PM
Well...
In the early years of the war when Studebaker used it to make bomber engines, it was a top secret where exactly and who was making the engines, but eventually word got out and it didn't really matter. One of the odd features about this plant is the walls. You will notice that compared to the engineering building and building 54/58 before that, this new building has NO windows except up fron, and that was a later add on. The area that SI occupies has no windows at all. The plant was made for blackout conditions. It makes some parts of the plant kind of erie...[:0]
One thing that I do want everybody to know is that we [u]ARE NOT AT THE FRONT OF THE BUILDING.</u> AM General still uses the main lobby of the building. Here is how to get to the SI portion: enter in the main driveway, but keep right all the way. There is a road that goes all the way around the plant. There is a semi intersection at the end of the drive near the old parking lots. You want to turn right as if you were a semi going to the docks, there are only docks on this side of the plant. (You can see them) You want to drive up to the water tower and look to your left past that. There will be a storage semi trailer parked out front and by then there will be a sign out front. There will be signs to get to the new store, but this is the easiest directions if they aren't for some reason.:)[:p]
Chris Dresbach
copcars1
03-28-2010, 07:09 PM
ok, this may be a dumb question but what is the new new SI
Chris_Dresbach
03-28-2010, 07:12 PM
Ed Reynolds now has a South Bend location.:) It is located in the Aviation plant Studebaker once used.
Chris Dresbach
Chris_Dresbach
03-28-2010, 07:15 PM
To get to SI, follow this line.:)
http://i768.photobucket.com/albums/xx323/chris_dresbach/scan0002-2.jpg
Chris Dresbach
Welcome
03-28-2010, 11:21 PM
[u]For GPS use:</u>
701 West Chippewa Ave.
South Bend, IN 46614
4961Studebaker
03-29-2010, 09:32 AM
[u]For GPS use:</u>
Also. N41.63602, W86.25889 for the road entrance
N41.64185, W86.25618 for the building entrance. :)
ChopStu
http://i132.photobucket.com/albums/q14/kkad0711/IMG_5411.jpg
116 weeks till completion.
Chris_Dresbach
03-29-2010, 05:26 PM
Or just drive aimlessley around South Bend.[:p]
Chris Dresbach
copcars1
03-29-2010, 06:26 PM
what is being built there?
