A few years ago I purchased 1557570 R1 heads that had R3 valves installed by a Studebaker vendor. I originally planned to install them on my R1 Lark but never got around to it. My new plan is to turn my engine into an R2. I do not want to change to dished pistons. I know the 1557582 R2 heads are 67cc while stock 1557570 R1/V-8 heads are 54cc. My heads with the R3 valves actually measure 58cc. In order to get my compression to where it needs to be to add a supercharger I need the volume in the cylinder heads to be close to 67cc. I can gain about 2cc by using a head gasket that is thicker than the shim but thinner than the composite gasket. That means I still need to remove 7cc of metal from the combustion chamber.
My question is could someone tell me the purpose of the raised sharp edges or shoulders around the valves. I circled the area I am referring to in the one photo. Would it be detrimental if that area was removed or rounded off? For comparison 7cc is approx. equivalent to 1 teaspoon. I don't know if that area if removed would increase my volume 7cc. Thanks for any and all comments and suggestions.
regards,
Jay
regards,
Jay
