View Full Version : Skybolt Six, smoking......
54-61-62
02-15-2007, 04:26 PM
I have a 64 Skybolt six, and the engines gotta come out to replace the flywheel ring-gear. While the engine is out I'm debating how much work I actually want to do on it, its hard for me to not rebuild an engine while its out, however spending a few extra hundred dollars for a full gasket set, rings, bearings, etc would be a strech for me right now.
Anyways, If you let the car sit a few days it smokes on startup, and hard acceleration. I've replaced valve seals on V8's and cured smoky engines but what about ohv sixes? Should I just rip the whole engine apart or bank on just replacing valve seals?
I should mention it has 60,000 miles.
Thanks
Kent
klifton1
02-15-2007, 04:40 PM
Did you do a compression check on it?
Klif
55 Speedster
42 Champ Coupe
54-61-62
02-15-2007, 06:45 PM
Compression checks out over 100lbs on all six cylenders...
53k
02-15-2007, 07:46 PM
OHV sixes need valve guide seals too. Replace then the same way you do an OHV V-8. I'm thinking the seals are the same as for V-8s.
Museum R-4 engine
N8N
02-15-2007, 07:49 PM
Check the oil drain back passages too. smoke on hard acceleration makes me think the head may be filling up with oil. Or it could just be rich jetting in the carb.
Transtar60
02-15-2007, 09:09 PM
Kent as Paul points out, the seal is the same and should be in valve grind gasket sets. It can be replaced on the engine with the same tools as the V8s.
Many but not all valve train parts are shared between 61-64 V8 and OHV 6's
3E38
4E2
4E28
5E13
7E7
8E7
8E12
8E28
4E2
59 Lark
etc
