Today I pulled the fan and hub on my Hawk so I could clean and paint them as well as the shroud. Waiting for a new heater valve so the coolant was drained already. Well there seems to be a lot of grease inside the hub and around the shaft of the pump. I thought it should be dry. No play or noise from the pump and seems to be working okay.
If it is going bad, like a seal on the shaft, this would be the time to replace. What do you all think? How hard are these to repair the first time?
Thanks for the thoughts
John Ratliff
John Ratliff
