I finally got around to changing my 62 Champ drums to the Chevy drums. I found the info in the forum and other web sites to be helpful but lacking. no one said anything about the wheel studs. The standard wheel stud (Dorman-610-036)would protrude above the face of the hub. Meaning you will have to open the drum holes to 5/8 inch.(I don't remember seeing that info either) so the drum will lay flat. I looked in every parts book I could find but all of the shoulders of the studs were to long. I had two different parts stores look and the machine shop try to find a stud with a short shoulder. NO LUCK. All were to long. I needed longer than stock studs and found one that was a 1 1/2 inch long (dorman 610-120)and one with a larger shoulder size and 1 3/4 inch long(Dorman 610-174)to use if your holes were larger. I still had to open the 1/2 inch holes in the drum to 5/8 inch but everything worked out great. no more beating on the puller to remove the hubs so you can check the rear brakes. Bob
I you wish to see pictures go to my club web site and look at the page titled Bob's Shop.
55pres- Cascade Chapter Oregon
