I also have an issue with the WCFB I just had rebuilt. I bought a kit from SI and took it to carb rebuild guy in my town. He is an older mechanic so at least he knew what it was.
Got the carb back and installed it with a new gasket that came with the kit. Pumped fuel up to the carb by spinning the engine. Hooked the line back up and tried to start. I always give a little splash of gas down the throat of a carb before I start cranking an engine that hasn't run for a while.
As soon as I poured gas in the throat of the carb, some ran out on the intake manifold[:0]. I pulled the carb back off and discovered there are a couple recessed areas on each side of the carb base plate. This appears to be where the gas was leaking out from. In each of these recessed arease I can see a screw head and a couple little mystery holes.
Any ideas on what I need to look for to get this leak fixed?
