timing for 57 silverhawk v8
  • timing for 57 silverhawk v8
    i was wanting to know if anyone knows the numbering for the distibutor cap? i am trying to get this old motor runing again but i think it is out of time. also is there a way to prime the oil pump on the stude?
    Kevin Phillips
    Jacksonville,AR
    53 commander
    If you are talking about the firing order it is cast into the intake manifold.Timing should be 4* before TDC.With the needle pointing at TDC the rotor sould point at #1 cyl. wire location on the dist.cap it then rotates counter-clockwise to the next fire which I believe is #8cyl. & so on till it completes the cycle.
        Hope this is helpful:
        Dwain G.
        Restorations by Skip Towne
          Dwain G.
            I prime the oil pump by making a tool to spin the pump. A length of bar stock with the end ground to match the pump, or a piece of 3/8 steel fuel line flattened on the end will do. Spin it CCW in your drill, you'll feel it when it primes the system.
            64 Commander 2 dr.
            64 Daytona HT
            63 Avanti R1
            63 Daytona convert
            63 Lark 2 door
            63 Lark 2 door #2
            62 Daytona HT/ 4 speed
            62 Lark 2 door
            62 GT Hawk 4 speed
            60 Lark HT
            60 Hawk
            59 3E truck
            52 Starliner
            51 Commander
            JDP Maryland
              64 Commander 2 dr.
              64 Daytona HT
              63 Avanti R1
              63 Daytona convert
              63 Lark 2 door
              63 Lark 2 door #2
              62 Lark 2 door
              62 GT Hawk 4 speed
              60 Lark HT
              60 Hawk
              59 3E truck
              52 Starliner
              51 Commander
              JDP Maryland
