View Full Version : commander water pump pulley size
Studecrg67
02-21-2010, 11:21 AM
I have 2 commander engines one is for a truck and has a 5 inch pulley and is 3/16 inch shorter than the car engine that has a 6 inch pulley. The question is should the 5 inch pulley be 3/16 inch shorter than the 6 inch pulley and the shorter (5 inch) pulley causes the alignment to be off in relation to the crank shaft pulley?
Gary C
02-23-2010, 09:52 PM
Without looking these pulleys up in the Truck Parts Catalog AND the '47-'50 Car Chassis Parts Catalog, I can only guess that 3/16" diff. would be the thickness of a spacer maybe?
It could be the problem is on the crank hub and pulley installation.
Or, the water pump hub is not pressed on to the correctl depth.
I am assuming you have a Commander Big 6 (245 ci.) right?
