Cleaning a 4V intake manifold.
  • Cleaning a 4V intake manifold.
    I think it's fairly clean,but is it normal to have a little bit of carbon lurking around inside?just seams like I blow air from side to side till the cows come home,and still not totally clean.
    Joseph R. Zeiger
    Joseph R. Zeiger
    You might try sand blasting the inside, but I'd wanna get it pretty clean before I put it on an engine. Short of porting the entire insides there's not much you can do.
    Tom Bredehoft
    ....On the road, again....
    '05 Legacy Ltd Wagon
    All Indiana built cars
      Joseph R. Zeiger
      I'd keep your cows away from your parts, Joe. []
      Chip
      '63 Cruiser daily driver
      '57 Packard wagon on the road!
      Chip
      '63 Cruiser
      '57 Packard wagon
      '61 Lark Regal 4 dr wagon
      '50 Commander 4 dr sedan
        Have it bead blasted then use a flexable drexel tool and grind and polish ports.
        Even though my Avanti engine is sporting a new Lionel Stone aluminum intake manifold, Michael Myer still used his drexel tool to polish out and remove any casting material and flashing from the intake ports.
        John
        63R-2386 under restoration & modification
        John
        63R-2386
        Resto-Mod by Michael Myer
          Hey Joe,
          Whats year make and model that your wrenching on? (Just Curious) ....Shane
            You could take it to a machine shop and have it hot-tanked. Personally, I wouldn't sand/bead blast it internally. I would never feel that I've gotten every last little bit of the abrasive out of the manifold.
            ErnieR
            1988 "Beater" Avanti---R5388 @ Macungie 2006
              Hi Joe. I sent you an email. Did you receive it? Thanks, Jeff
                Hi Shane, it's a full flow 289 with AFB and truck automatic.going in my 63 Champ.hey I sent you another email,still must not be working?
                Joseph R. Zeiger
                Joseph R. Zeiger
                  Hi Jeff, I did'nt get your email.
                  Joseph R. Zeiger
                  Joseph R. Zeiger
                    Joe,
                    Must be a problem with the Forum email system. I tried you a few times yesterday and today. Can you try a reply back please? Thanks, Jeff
                      Joseph R. Zeiger
                      BY pass the forum, go from yahoo new mail, shnkendrick@yahoo.com, did you get the pics I sent you? Shane
                        I personally don't recommend bead blasting any part on the intake system as I don't believe that all of the blasting media can be removed and the last thing your engine needs is glass bead media going into the cylinders. A thorough hot tank cleaning will remove the carbon inside of the manifold. Bud
