I bought this about a year ago and haven't done anything with it. came out of a 64 GT Hawk. Unknown condition, but clean under the valve covers. Comes with all accessories shown including Hurst shifter, but no carb. Prefer local pick up or can deliver in the Seattle area. $500
289/4 speed
Could be worse; I'm in the area, but don't have 500 bucks to spend on it right now. Otherwise, I'd be ALL over it! Ya see, I'm planning out a engine build (one of 2 actually, already got one engine.), and this is just what I need for it! Arrggghh!!!![}]
Good luck with your sale! I'd be surprised if it doesn't sell quicker than most.
quote:Originally posted by COMMANDERPINK1
If only you were closer
Tom
[IMG][/IMG]
'61 lark deluxe 4 door wagonDylan Wills
Everett, Wa.
1961 Lark 4 door wagon
1914 Ford Model T
Could you tell us the Engine Serial Number please?
You will find your Engine Serial Number on the Driver's side front corner of the Block, TOP of the block, on a machined flat pad and are STAMPED into the block.
The raised numbers on the Right side are all the same for each major engine block change as they are part of the casting, those are just the Casting Number.
This usually requires CLEANING the pad to read the stampings. [^]
StudeRichStudeRich
Since I am going to be his the area with a truck tomorrow, I thought I might as well pick it up.
The engine is going straight to the machine shop for a tear-down and look-see. Wish me luck. If all the iron and steel parts are usable, it is a good buy. I've also bought core engines where literally nothing was usable.
thnx, jack vines
PackardV8PackardV8
thnx, jack vines
Bellingham, WA
Bellingham, WA
Yep CASO for sure
Mabel 1949 Champion
Hawk 1957 Silverhawk
Gus 1958 Transtar
The Prez 1955 President State
Blu 1957 Golden Hawk
Fresno,Ca
Mabel 1949 Champion
Gus 1958 Transtar
Fresno,Ca
