I have a couple of 5 speed od bell housings to sell, e-me if you want one, Allen. Yes I am sorry as Rich stated, Studebaker.
5 speed bellhousing's
Maybe Allen means the Truck H.D. 5 speed, that would be the only bolt-on Studebaker 5 Speed clutch housing there is! [:0]
These have the same bolt pattern as the H.D. 4 Speed T-98, but are thicker for the New Process 5 Direct or 5 O.D. if they are the real deal. They require a "C" or "T" Cab Truck to install them in. [:0]
StudeRichStudeRich
These have the same bolt pattern as the H.D. 4 Speed T-98, but are thicker for the New Process 5 Direct or 5 O.D. if they are the real deal. [u]They require a "C" or "T" Cab Truck to install them in.</u> [:0]
<h5>Mark
'57 Transtar Deluxe
Vancouver Island Chapter
Mark Hayden
'66 Commander
Ok, the T-98 IS a heavy Duty serious TRUCK 4 Speed Trans. with a compound Low, but I misspoke calling it a H.D. because technically as Transtar60 said, Studebaker HAD a 4 Speed actually called a "Heavy Duty 4 Speed", it could be described as WAY Heavy Duty, for the Diesel. [^]
StudeRichStudeRich
