View Full Version : Reminder (Pictures Added)
Anne F. Goodman
02-09-2010, 09:50 AM
All this talk about Toyota's has got me to thinking. I want to remind everyone to check your return springs on your cars make sure they are working properly. Go over in your mind just what to do with a stuck gas pedal. Just a reminder from experience. We lost a Studebaker and hurt a few kids.
http://i122.photobucket.com/albums/o269/nw3anne/55%20Champion/stude1013.jpg
http://i122.photobucket.com/albums/o269/nw3anne/55%20Champion/stude1014.jpg
Mabel 1949 Champion
Hawk 1957 Silverhawk
Gus 1958 Transtar
The Prez 1955 President State
Blu 1957 Golden Hawk
Fresno,Ca
http://i122.photobucket.com/albums/o269/nw3anne/Mabel.jpg?t=1165475035http://i122.photobucket.com/albums/o269/nw3anne/xmasannecopy.jpghttp://i122.photobucket.com/albums/o269/nw3anne/GusMater.jpghttp://s122.photobucket.com/albums/o269/nw3anne/th_DSCN17232008-01-01.jpghttp://i122.photobucket.com/albums/o269/nw3anne/54%20Commander%20Regal%20Coupe/3539580552_f5500eb0d8-1-1.jpghttp://i676.photobucket.com/albums/vv124/nw3anne2/DSCN51082009-10-11-1-1.jpg
Pat Dilling
02-09-2010, 09:59 AM
Great point Anne! And for those Safety engineers among us who don't want to take a chance, a second throttle return spring is not a bad idea, saves you if one spring should break. Many cars come with a dual throttle return spring, usually it is a smaller diameter spring inside a larger one. That way they hook up to the same place and do not take extra space or connections.
Pat
Pat Dilling
Olivehurst, CA
http://i112.photobucket.com/albums/n194/stucool53/StuCoolsmallerSigpic.jpg
LS1 Engine Swap Journal: http://www.hotrodders.com/forum/journal.php?action=view&journalid=33611
Milaca
I had this happen on a loaded gravel truck once and so I tied my foot to the accelerator pedal with some wire and got the load delivered. :)
http://farm3.static.flickr.com/2671/4149448710_41d6dfe9bc_t.jpg
SnowLark
In the middle of Minnestudea
14x7
02-09-2010, 12:37 PM
My brother had it happen with a street &strip mustang , and there was 4 of us in the car , we hit a pole. Always turn the key off ,if this should happen. Or shift into neutral and turn the key off.
Jeff_H
02-09-2010, 01:03 PM
Page 11 of the government safety test spec calls out the requirement there be 2 "sources of energy" aka springs to force the throttle closed. I think this spec came out originally in about 1974.
http://www.nhtsa.dot.gov/staticfiles/DOT/NHTSA/Vehicle%20Safety/Test%20Procedures/Associated%20Files/TP-124-06.pdf
Vehicles I am familiar with have a clock spring on the throttle shaft and coil spring made into the pedal cable to meet this requirement. I bet it would not be too difficult to incorporate a "hidden" spring if original appearance around the carb is desired.
Edit:
Apparently, these dual springs are available to replace the singles.
http://www.streetperformance.com/ART/PRODUCTS/10021447/hpPOL6052.jpg
http://www.streetperformance.com/ART/PRODUCTS/100489/19.jpg
Don't look stock/original for show judging but not totally out of place either.
Jeff in ND
http://i156.photobucket.com/albums/t5/ee-engineer/devilstowerthumbnail.jpg
'53 Champion Hardtop
Mark57
02-09-2010, 01:21 PM
Thanks for this post... it IS a good reminder. Having just worked on the engine in my truck, I had removed the throttle linkage for servicing. Even though I reattached the return spring, it did not have quite enough tension so that when I took the truck for a test drive afterwards, the throttle stuck open just enough to prevent the overdrive from engaging (when removing your foot from the gas pedal).
'Course with a stick, the easiest thing to do with a stuck throttle is to push the clutch pedal down. ;)
<h5>Mark
'57 Transtar Deluxe
Vancouver Island Chapter
http://i186.photobucket.com/albums/x153/MarkH57/046a.jpg
tutone63
02-09-2010, 06:38 PM
Pat
Pat Dilling
Olivehurst, CA
Yup, just put a second throttle return spring on my Lark this fall. Now the pedal is a bit stiffer than I like, but the peace of mind that it gives me is well worth it. Cheap way to add some safety to your Studebaker.
http://i253.photobucket.com/albums/hh54/tutone63/Mobile%20Uploads/nixon3_0001-1.jpghttp://www.thelincolnforum.net/phpbb3/images/smilies/035.gif
1963 Lark, 259 V8, two-tone paint, Twin Traction.
COMMANDERPINK1
02-09-2010, 07:17 PM
This whole Toyota thing is a reminder that there are to many disstraction while driving these days. Remember my drivers education class that our Instructor taught us -to leave yourself an out- another words be aware of your surronding for what if.
Tom
http://i759.photobucket.com/albums/xx240/TOMLSEXTON/Iowa036.jpg
Gary1953
02-09-2010, 08:34 PM
ann,
Thank you for the post. I will have to install an extra spring in my car now.
http://i98.photobucket.com/albums/l269/gsandes50/116-1-1-1.jpg
Gary Sanders
Nixa, MO
bams50
02-09-2010, 08:51 PM
I still remember, Anne. Thanks for caring![^]
Parish, central NY 13131
http://www.patrioticon.org/images/flag1-1.gif
63t-cab
02-09-2010, 09:40 PM
Well I just hope that no one was hurt to any real extent !!!!!!!!
Joseph R. Zeiger
Milaca
02-09-2010, 11:27 PM
The reason that the return spring broke in the 1982 Ford L9000 Cummins diesel powered gravel truck that I was driving is, with 500,000 plus miles on the truck, the spring and spring mount wore into each other. Being that the spring got worn thin, it finally gave out. I drilled a new hole in the spring mount and put a new spring in place and all was fine. So when inspecting your return spring you should also take a close look at the spring mount to insure that it doesnt have a razor sharp edge that may dig into the spring.
SnowLark
bams50
02-10-2010, 04:17 AM
Ultimately everyone was OK. Here's the thread:
http://forum.studebakerdriversclub.com/topic.asp?TOPIC_ID=12105
