I've had my '50 Champion for a year and a half now and have put about 2000 miles on it. Last winter I changed the oil but not the filter and that's about the only maintenance I've done to it. I did a search for "annual maintenance" on the site but nothing showed up. I'm wondering what I should do. Should I change the oil again? Do I need a new oil filter? If so can I buy one at my local auto parts store or do I need to get one from a Studebaker parts place? What about the original air filter and gas filter? Is a lube job necessary? If so can I get one at my local oil change shop? How about flushing the radiator? Does it need any other annual maintenance? The engine still dies when I stop at a red light or slow down to make a turn which is getting a little old. Does anyone know what could cause that? Also, the speedometer cable still makes a lot of noise over 20 mph. I was going to unscrew it from the back of the speedo but I couldn't figure out how. Should I just unscrew it from the transmission instead so the noise will stop? Would replacing the cable solve the problem? What I really need is someone who knows old cars to go through it and fix all these little problems for me for a few bucks. I have to fill the master cylinder with brake fluid every couple of months too. Is that normal? Any suggestions? Sorry about all the questions....
1950 Champion 2 Dr. Sedan
