View Full Version : Missing Hawk Body Mounting Parts
hank63
02-08-2007, 09:26 AM
Working on rusty panels on my -63 Hawk, I found the body mounting just behind the door is missing something. The bracket on the chassis rail is there, there's a reinforcing plate under the floor panel, but there is nothing between the 2, just an air gap.
Does anybody have a photo / picture of what is supposed to sit in the air gap? (There's a bolt and some shims in the chassis bracket, but no connection whatsoever with the body).
Thanks in advance /H
rockne10
02-08-2007, 10:32 PM
I assume you're missing the rubber pad. It's just a piece of reinforced rubber, like the sidewall of a tire. Studebaker International has them in 1/8, 1/4 and 1/2 inch for $2 each, or you could cut some from an old tire. When you tighten the bolt you may find you will need to adjust the fit of the door and the striker plate.
hank63
02-09-2007, 09:41 AM
No, the "shims" are there, on the bolt in the chassis bracket. The problem is that there is a gap between the body and the bolt & shims. The plate on the underside of the floor, is nice and thick but is >1 inch above the chassis bracket.
Is the bolt supposed to be attached to the floor with a nut under the chassis bracket, or is there a "top-hat" section coming down from the floor to meet the chassis bracket, or .............
/H
JDP
02-09-2007, 10:49 AM
Are the rocker boxes rusted out ? You should have a boxed section that runs from the bottom of the outer rocker flange, over a few inches, then up to the floor.
64 Commander 2 dr.
64 Daytona HT
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Daytona HT/ 4 speed
62 Lark 2 door
62 GT Hawk 4 speed
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
02-09-2007, 02:46 PM
There are two body mounts (on each side) behind the door. One immediately behind the door, and one toward the front of the wheel well opening.
Here are all 4 on my '63 Hawk.
http://farm1.static.flickr.com/151/384849623_f6c5b34551.jpg
Right side nearest rear of door.
http://farm1.static.flickr.com/140/384849625_2a75d9a259.jpg
Right side nearest front of wheel well.
http://farm1.static.flickr.com/154/384849627_334bef5da6.jpg
Left side nearest rear of door.
http://farm1.static.flickr.com/147/384849629_63ec1bca9d.jpg
Left side nearest front of wheel well.
02-09-2007, 10:07 PM
quote:Originally posted by rockne10
Dick,
On my '53 I only have one 1/4" rubber at each mount. Maybe the Hawks are different
My '54 Starliner only has 1 or 2 per mount also. The body has never been off it.
This Hawk had a body off restoration in '80. I'm not sure if all/most of the later Hawks had this many or just this car. It seems to sit correctly, however.
rockne10
02-09-2007, 10:58 PM
Dick,
On my '53 I only have one 1/4" rubber at each mount. Maybe the Hawks are different, with the hog troughs. On my car that would amount to a lift kit.:D
Good photos; should answer Hank's question.
Brad Johnson
33 Rockne 10
51 commander Starlight
53 Commander Starlight
http://i57.photobucket.com/albums/g233/rockne10/ddc714b7.jpg
Dwain G.
02-10-2007, 01:56 AM
There's another under-belly shot in this ebay listing:
http://cgi.ebay.com/ebaymotors/_W0QQcmdZViewItemQQcategoryZ6466QQihZ006QQitemZ160083879585QQrdZ1
http://home.comcast.net/~jdwain/63.63.jpg
Dwain G.
hank63
02-10-2007, 07:12 AM
Dick, thanks for the photo's. Exactly what I was looking for.
/H
