Hi guys. The inner fenders on the 64-66 are 3 pieces welded together. I have heard the piece behind the headlights on the dual headlight cars are hard to find.Any truth to that? Thanks!
64-66 inner fender sheet metal question
Yes, SASCO was out of them quite a while before they closed.
Also many used ones are rusted out or mangled and can't be used for spares.
The three pieces need to be fitted to the car before welding.
StudeRichStudeRich
Could always consider switching to the '64 single headlamp style... I thought I read somewhere that those pieces were still around someplace.
<h5>Mark
'57 Transtar Deluxe
Vancouver Island Chapter
Mark Hayden
'66 Commander
The "weights" on the convertibles (at least the 62's) are bolted to the front nose panel. And they are NOT fun to install by yourself! LOL
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Behind that grill panel for the convertibles weights, attached to the front inner fender panel, are two sheet metal brackets that are either spot welded, or just welded on. They don't just hang on the front panel. The long weight bolts hold it all together through the front panel, weights and those brackets on the inner fender to diminish any cowl shake.
We are actually talking about the "Baffles" or "Air Deflectors", these are BEHIND the headlight buckets and WELDED to the Inner fender, and one side or both are now NLA.
The '62-'63 grille PANEL is related somewhat to this discussion, but not '64's and yes the 2 Hd. Lt. '64 [u]GRILLE</u> can be converted to 4.
On '62-'63 Larks, the Convertible/Wagonaire WEIGHTS are on the FRONT PANEL. on '64's they are on the lower chin pan (stone pan).
Nomenclature, it'll bite you every time! Lol!
StudeRichStudeRich
Here's the front of my 66:
Note that there is plenty of room to cut for the dual buckets, but that the hole for the single buckets is quite large - the excess area will need to be filled in.
Scott Rodgers
Los Angeles
SDC Member since 1989
'60 Lark HT
'63 Wagonaire
'66 FrankenbakerScott Rodgers
Los Angeles
\'60 Lark HT
\'63 Wagonaire
\'66 Frankenbaker
