Same 61 4-speed Hawk. I understand that it needs springs to keep the tunnel from getting scuffed. My point is that the car has a driveshaft that is 3.00" in diameter in a floor pan that was designed for a two piece small diameter shaft. I was told that it had a heavy duty drive shaft. Was there such an option? Do all four speed cars have the big shaft?
Who is the best vendor for springs? Eaton says they can make a set that will have a stock height but be a bit stiffer than stack. That is what I would like.
If I add factory traction bars can I weld the bracket on without disassembling the housing?
Jon Kammer
Jon Kammer
