Gary Ash, call the factory !
Gary Ash
Dartmouth, Mass.
’41 Commander Land Cruiser
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
I don't have info on what cam was used. In my computer modeling of the engine performance, the best grind I have come up with is the same one used in the 245 cu in Commander 6 trucks through 1960. It calculated even better than some hot rod cams for flatheads. I got the blueprints of the original stock cam profile from the Studebaker Museum.
The valves are so close together already that there is no hope for bigger valves. I do have an aluminum head with 6.5:1 compression, like the racing engines.
I weighed the orignal flywheel onthe engine that I will use - it was over 50 lbs. That might want to get replaced with aluminum or at least machined a lot.
[img=left]http://www.studegarage.com/images/indy/gary_indycar25_vvsm.jpg[/img=left] Gary Ash
Dartmouth, Mass.
'48 M5
web site at http://www.studegarage.comGary Ash
Dartmouth, Mass.
'48 M5
