Hi guys,I have removed the steering column from the outer jacket and I find that there is a nylon type bush at the bottom of the outer jacket and a steel bush near the steering wheel inside which the column turns. Is this correct or should these be bearings. with the steering column disconnected it is still stiff to turn the steering wheel? I am concerned that these bushes are the problem ?
