Greetings. What do you guys recommend for a '64 Daytona 4Dr w/259 to improve handling. Mostly for the street, but who knows, maybe an occasional autocross. Sway bars F/R, springs, shocks??? Thanks. Bob
Better handling
Look up ROADRACELARK
He has done wonders with his Lark. What works on other brands work
on Studes as well, bigger sway bars, better shocks, lower center of
gravity, lighten it up, bigger diameter wheels (up to 18") w/wider
tires are the norm. Sway Bars can be got from Tbow, better shocks
can be made to fit, my current plan is to use 90's Impala SS shocks
on my Avanti with early Stude lower shock plates in the rear. You
cant go wrong with Bilstein, though be prepared for 100 a shock. If
you are serious you should plan to at the least go with 16" wheels.
Tom
'63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: TKO 5-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires'63 Avanti R1, '03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, TKO 5-spd, Ported heads w/SST full flow valves.
