Grateful for your help. 1957 Silver Hawk 289 3 spd man.3 on tree. Body off restoration project. New engine & trans mounts are installed. The clutch linkage is hitting the crossmember...looks like a 3/16" shim at trans mount would allow the linkage to travel in the "ramp" formed in the crossmember. Can not find any information in manual. The shaft (1546329) & levers are good (splines tight & no slipage), the sleeve has very slight play, and the bracket/ballstud assembly seems good. Does the trans mount need shims or am I just not seeing the actual problem?
Ray Stewart SDC
51 pick-up
57 silver hawk
62 lark
Ray Stewart SDC
51 pick-up
57 silver hawk
62 lark
