I recently acquired a 55 commander..A few areas of rust but not to bad,I have completly taken the car apart.Fenders ,doors nhood etc.I have removed the eng and tranny.Interior of car stripped dash ,headliner etc.The wiring harness removed.I am debating whether to remove the body from the frame.It looks fairly simple.It looks as if there are 10 or so bolts that hold the frame to the body.Are there any traps that i might encounter taking the body off.It is a 2 door hardtop.If i keep track of the shims and pads between the body and frame will I have a problem when I put the body to the frame.
Got a quote of 1000$ to blast all parts and the frame and body.Is this a decent price.Also concerned about the surface after blasting.The guy tht runs the shop says use a good 2part epoxy primer ,The surface will be as smooth as a babys butt.Any info will be appreciated Thanks.
