I am looking for a replacement starter for my 61 lark. Any one have any suggestions on makes and sizes that will match up to replace my old one?
Replacement starter for lark
Any 12V Studebaker V-8 starter that will fit a car with the same transmission as yours. (stickshift and automatic starters have a different "nose.") Given the choice, I'd probably look for a 56-61 Delco starter.
I actually have a '61 Delco starter on my '55 with a 4-speed, if you're a "numbers matching" kind of guy, but I'd obviously want something in trade so I can still start my car
Can't your local auto electric shop fix the old one?
Way more CASO!Brad Johnson,
'56 Sky Hawk in process
every true CASO should have two starters that fit their car, that way when one craps out you rebuild it after you swap in the other one
If you have a V8, check with Phil at http://www.fairbornstudebaker.com/
He has a Hi Torque starter for V8s.
Other than a starter made for a Studebaker engine none will fit.
3E38
4E2
4E28
5E13
7E7
8E7
8E12
8E28
59 Lark
etc
