View Full Version : '47 rear window glass installation...how ??
bradnree
02-02-2007, 07:01 PM
Installing a rear glass is like installing a round peg in a square hole to this point. I've tried to install the used glass and old rubber all in one sweep as per the manual---which makes it sound so easy ( where is that engineer ? ). I've lubed the rubber and that still does not help. I am using the old rubber which suprisingly is still flexible. It's like there is too much rubber but I know it will go in. The rubber that goes inside is very wide and needs to to through the hole from the outside. The glass fits the rubber perfectly so it is the right glass. How to tips please.....................Brad
klifton1
02-02-2007, 07:56 PM
Some rubber goes from the inside out.
Klif
55 Speedster
42 Champ Coupe
Dwain G.
02-02-2007, 08:32 PM
Actually, I think you'll find the front and rear glass and seal is removed to the inside of the car, and installed from the inside. Just backwards to what you're used to. Studebaker even sent these instructions from PPG to dealers in a service bulletin.
http://home.comcast.net/~jdwain/wshldtrim.pdf
Dwain G.
(We're not called 'hillbillies' any more....we're now Ozark Americans)!
ST2DE5
02-02-2007, 10:06 PM
The way I did it on the bus. coupe. I took a nylon cord and wraped it around with a lot of baby oil. Have somebody on the inside of the car to hold it.Put the rubber on the center post first and then start pulling the string out as they push in. I started pulling at the bottom first. I really didn't have problem but it is diffently a 2 man job. Some others might have a better way but it worked for me. And don't break them I don't have anymore:D
52 Ragtop
02-02-2007, 11:13 PM
It's easy, Pay a glass shop to do it! Buy new weatherstrip, and let the Pros do it! Call Collision Shops, go to car shows and ASK who does a good job.
I took my 52 to the local glass shop, turned out, they are BIG into 57 Chevys, and knew what they were doing, I think Ted also took the Chickenhawk to them.
Jim
fpstude
02-03-2007, 12:04 AM
As indicated above, the glass does install from the inside of the car. It is quite a project, but can be done. We did this 20 years ago when our '50 Champ was brought back to life. My wife wrote up the installation process we used. I believe it is too long to put here, but I'd be happy to forward the *.doc file if you email me.
Perry
'23 Special Six,
'50 Business Champ,
'50 Starlight Champ,
'60 Lark droptop,
'63 GT
60Lark
02-03-2007, 12:39 AM
I install the glass and rubber seal similar to ST2DE5, I use a piece of small diameter nylon rope, either 1/8" or 3/16" my son-in-law inside holding the glass and seal in place with a little pressure (not to much, old glass can be brittle/fragile) I keep the lip of the rubber seal wet with glass cleaner, with the rubber seal lip started on the bottom, I pull the cord seating the rubber from the bottom up, around the entire glass. After everything is prepaired, it only takes a matter of minutes to actually get the glass and seal installed. The prep time is actually much longer than the install time. I like using the window or glass cleaner because it is so much easier to clean up after the glass is in place. I have used baby oil as ST2DE5 stated, but It is a mess to clean up after the fact. Just my Opinion
http://im1.shutterfly.com/procserv/47b6ce20b3127cce8d0e3b50356c00000000400CcNWTlozYsb http://im1.shutterfly.com/procserv/47b6dc03b3127cce970d7aafd15f00000010100CcNWTlozYsb
Studebaker Fever
60 Lark
51 Champion
Phil
Arnold, Missouri
CHAMP
02-03-2007, 06:38 AM
I like to use the Silicone paste. I got it at NAPA.:)
KGlowacky
02-03-2007, 08:20 AM
does all years install from th inside??? or at some point does this reverse and go from the outside. Asking for my 56 wagon front and back. Thanks
ST2DE5
02-03-2007, 11:12 AM
I don't really like silicone any thing against the paint. Diffently under rubber. In my opinion silicone and paint don't get a long.
CHAMP
02-03-2007, 07:18 PM
I am talking about silicone lubricant not sealer or adhesive.
rockne10
02-03-2007, 07:29 PM
Later years were installed from the outside but I don't know when the change occured. I'm sure someone here will know.
klifton1
02-03-2007, 07:30 PM
At least by 1953.
Klif
55 Speedster
42 Champ Coupe
CHAMP
02-03-2007, 07:32 PM
BTW, one of the advantages of Dot-5 Silicone Brake Fluid is that it will not harm the paint.
CHAMP
02-03-2007, 08:03 PM
On my first post on this thread I should have said silicone clear gel lubricant instead of paste. My mistake,SORRY.
