View Full Version : Twin Traction Truck rear ends
mbstude
12-26-2009, 09:41 AM
I'd like to put a TT rear end in my '59 half ton pickup. Preferably a 3.54 to 3.90 or so ratio. If anybody has one, I have a 3.31 TT Dana 44 from a Lark I'd trade. Even has brand new flanged axles in it.
Matthew Burnette
Your Friendly Stude Trim Bender
http://i280.photobucket.com/albums/kk179/1959S2D/th_mouldinnnnn001-1.jpg
candbstudebakers
12-26-2009, 11:37 AM
Just cut the center out of a 455.1 last week, saving the unit for something later, saved the axles also...Bob
Castro Valley, CA
canbstudebakers-
http://i691.photobucket.com/albums/vv271/canbstudebakers/CedarRapids210.jpg
barnlark
12-26-2009, 12:07 PM
Now that's a ratio!
289stude
12-26-2009, 01:23 PM
Hey Bob will that set up work in a car axle? if so why don't you just throw it in the trunk of Peters lark before they ship it to me. I am looking for a 4:55 so I can take that little lark to the drags this summer. Seems like the 4:55 cars were putting up much better times.
John
63' R1 Wagonaire
63' 8E45 Detroit
53' 2R5 R1 Powershift TT Under Construction
57' Transtar 304 NP540 4:09 TT Under Construction (in Picture)
58' 3E6D Stock
59' 4E2 122 Scotsman Deluxe V8 4spd curb side fender
61' 6E7 122 Factory Auto
http://i126.photobucket.com/albums/p99/289stude/transtar3-1-2.jpg
jackb
12-26-2009, 01:24 PM
I have 2 Champ truck R/A here in Mass. I could take them to York for you if need be. Both are 4.09's. The TT has over 100K on it, but runs well when removed for 3.31 TT I had made up. I have a NOS (almost) here that is open with maybe 500 miles on it....
candbstudebakers
12-26-2009, 08:45 PM
John I don't think the gears will work as the axles are larger but I keep it for the the TT section I think they are the same in all 44's truck or car but not the gears...Bob
Castro Valley, CA
canbstudebakers-
12-26-2009, 08:48 PM
If you want anything from a 3.73 or lower (numerical)gearing, it's highly unlikely you're gonna find one for a 1/2ton truck. The 3.73 was the lowest (numerically) that you could get in a half ton and most of those would've been in trucks with an automatic. BUT! If you can find the gearcase assy from a 44 rear out of a car, it'll swap in the housing of a truck rear end, no problem! The parts catalogs confirm the part numbers for the gearcase parts are the same from car to truck.;)
http://imagehost.vendio.com/a/30906179/aview/58_Avatar.jpg
1963 Cruiser
1957 President two door
mbstude
12-26-2009, 09:11 PM
Biggs, the rear in the truck now is the original 4.27 casing. Years back my granddad swapped the "innards" from a '60 Hawk rear into the truck casing, giving it a 3.54 ratio. I'll leave it like it is if I can't find a Twin Trac.
Milaca
12-26-2009, 10:51 PM
I took the Twin-Traction gearing from a 1964 Cruiser and put it into a 1963 Champ 1/2 ton. The car axle shafts are a smaller diameter at the hub end but the splined end is the same diameter as a pickup axle shaft.
http://farm3.static.flickr.com/2714/4214451713_e3b746ee90_t.jpg
1949 2R17
R is for Rusty
In the middle of Minnesota
sals54
12-26-2009, 11:12 PM
Matt, I have one here in California. I sent a PM to you.
sals54
http://i296.photobucket.com/albums/mm197/sals54/NewSignature.jpg
