I bought an engine with number P98238 stamped on the block and the last three casting numbers on the heads is 570. This should make it a 1963 289. Looking down the spark plug holes you can see that it has flat top .030 over pistons. Shouldn't this have dished pistons? If it has flat tops it may have had a 259 crank installed? Is there any way to tell what engine it is other than checking the stroke?
Thanks for your input!!
Rob
Rob
