turbocharged.
Love that car, even though it isn't a real convertible. I wonder how it seals up? Wish the seller would have shown more detail on the homemade top setup.
Parish, central NY 13131
What's up with what? [)]
So, thats what a finished product looks like when a six is joined with a turbo setup, neat...
[IMG=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/55%20Studebaker%20Commander%20Streetrod%20Project/P1010531-1.jpg[/IMG=left]
[IMG=left]http://i158.photobucket.com/albums/t102/PlainBrownR2/55%20Studebaker%20Commander%20Streetrod%20Project/P1010550-1.jpg[/IMG=left]
[IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/Ex%20Studebaker%20Plant%20Locomotive/P1000578-1.jpg[/IMG=right]
[IMG=right]http://i158.photobucket.com/albums/t102/PlainBrownR2/My%201964%20Studebaker%20Commander%20R2/P1010168.jpg[/IMG=right]
That is one heckova nice application. I like the way he used the airbox from a Golden Hawk as a pressure box. I ran a turbo on a flat 6 in my 54 Coupe for a short time. It makes for a fun little ride. The turbo I used was from an Audi 5000. I ran it through a sealed 4 bbl carb. instead of a pressure box. Great fun. I still have the setup in the barn. A turbo will really make a flat 6 come alive.
sals54
sals54
1950? Must have been one of those rare "year ahead" options with the 51 front sheet metal and suspension. I really like the car but I think that if I were going to spend that much money I would upgrade the brakes and refresh the suspension so that it wouldn't require those things stuffed into the coil springs. If you want more pictures...he has a "more pictures" link to his photobucket album of the car. Looks to me that it would be a great "fair weather" car. I wonder what measures (if any) were taken to stiffen the car after removing the top.
SDC member since 1975John Clary
Besides losing a business coupe
There is some real nice quality work there....
Interesting what people see...
What's with the axle u-bolts?
Why aren't the bottoms painted?
Just curious....
Sals-I have a nice .030 over 185 that I did a valve job on and it's just sitting on my garage floor waiting for manifolds of some sort. I have a bunch of 5.0 mustang injection stuff and I got hold of a turbo off an 84 ford truck diesel. I figure the 5.0 injectors (3) might be enough for the six on a batch fire deal, but I really have no idea WTH I'm doing. Some kinda crank fire deal, maybe. Have you ever posted pics or info about your setup? I'd like to put something together that is as simple as possible but three injectors, turbo, O2 sensor, ecm, who knows. The high compression heads available for champion motors are still way too low to be getting serious. And I still have this 57 SH (finless) with OD and 3.90 TT this could go into.
People are getting confused on how the intricacies of the FI system functions......
Hmm, this looks like a job for.......a brief summary [)]
Yeah, that's the educator side speaking [)]
StudeRichStudeRich
Buddymander,
I don't think I still have any pictures of the total setup as it looked under the hood. Dick Datson has pictures of it in his old Turbo publication. I do have pix of the intake and exhaust, though. I did the most simple of jobs since mine was not intended to be a regular daily driven setup in its current form. A few tweaks, though would make it very streetable.
These are the parts I built to make the magic happen. Easy stuff to fabricate. I used a bonnet on the carb and blew straight through the carb. The carb is sealed. The Audi Turbo would build up to 14 lbs of boost. Too much for a flat 6 piston to handle. I found out later that one of the pistons was damaged as a result of the high boost. All strictly low-tech. Made my 54 Coupe go about 115 mph, though. That's not too bad for 169 cubic inches. Remember, the damaged piston was caused in less than 20 miles of hard running. Probably running a bit lean and way too hot from over-boosting it. I believe, if it was kept under 10 lbs of boost and ran slightly richer, it would make a very potent and reliable high horsepower flat 6. The clutch is another story altogether... By this time, my V8 rebuild was done and I was ready for a daily driver again. It was fun while it lasted. Good luck with yours.
sals54
sals54
