I am in the final stages of restoring a 66 Daytona SS.It has a 283 V8,p/s p/b and AC The engine was started last week for the 1 st time and immediately the front wheels turned to the right.The only way to turn them back was to shut the engine off,when I started it again,it turned right again.It has new power steering hoses and the ram was rebuilt, any suggestions ???
Power Steering Question
I had that happen the other day on mine when I started. had the two hoses backward that led to the cylinder.
Switched them and it stop pulling to one side.
quote:Originally posted by Studeman
Reverse the hoses on the power cylinder...
100% sure that is what it is
Ray
Sounds like you need to get a kit for your control valve. There's a spool valve in there, with springs on either end to center it. Could be one of the springs is broken, or else the valve spool has become jammed for some reason.
SI, amongst others, has the control valve kits. The unit is not too hard to take apart.
Gord Richmond, within Weasel range of the Alberta BadlandsGord Richmond, within Weasel range of the Alberta Badlands
Sometimes it takes brute force and awkwardness to solve some problems. I guess that's what the BFH is for.
Tom Bredehoft
....On the road, again....
'05 Legacy Ltd Wagon
All Indiana built cars
