Fram air cleaner
  • Fram air cleaner
    Looking for a air cleaner for a 4 barrel Carter. The base has FRAM 2504-KA5. Thanks
    Here's a link with a list of modern day air filters for Studebakers.
    The Fram CA168PL is specified for a 259 & 289 V8 with 4 barrel.
    Lark ala mode
    In the middle of Minnesota
    In the middle of MinneSTUDEa.
      Problem I have had with regular air cleaners for the 62 259 4 barrel is that they don,t clear the automatic choke. I don't know what the one I listed is, however it is on another rig with a 259 and clears the choke. Thanks
        I'm sorry, I misunderstood. I thought you wanted just the filter element but you are looking for the entire assembly. Does anyone have an air cleaner assembly for a 4 barrel Carter?
        Lark ala mode
          Irv, I sent you an email.
          Bill
            why not try a 14 inch air cleaner assy. from you local speed shop.they usually work very well.cal custom,edelbrock,offy.mr.gasket etc......................................
            2006,f-150,2x4,v-6,5-speed manual,8ft bed, will post stude info when i get it on the road.
