View Full Version : WILL A WCFB CARB WORK WITH SN92
hurricane
01-27-2007, 09:44 AM
IHAVE A 55 PREZ COUPE I JUST GOT A SN92 PAXTON WILL IT WORK WITH
WCFB CARB WITH THIS PAXTON BLOW THROUGH SYSTEM OR WHAT CAB TO USE
THANKS SPENCE
GTtim
01-27-2007, 10:38 AM
We need more info, Spence. Do you plan on putting the carb in a box, R3 style or were you planning on using a bonnet at the top of the carb?
Tim K.
'64 R2 GT Hawk
hurricane
01-27-2007, 10:41 AM
goin to use a bonnet
Tim K.
'64 R2 GT Hawk
JDP
01-27-2007, 11:01 AM
With the amount of money invested in the entire supercharger setup, it would be false economy to try and use the smaller WCFB. Are using the Avanti style side mount ?
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Daytona HT/ 4 speed
62 Lark 2 door
62 GT Hawk 4 speed
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
GTtim
01-27-2007, 11:08 AM
Lots of good info here: http://www.vs57.com/carb.htm
Hope this helps.
Tim K.
'64 R2 GT Hawk
hurricane
01-27-2007, 11:11 AM
have to use side mount to clear hood on the 55prez coupe eny help on this i like to use a serpentein belt on it if tha can happen what other carb can i use thank spence
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
62 GT Hawk 4 speed
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
JDP
01-27-2007, 04:11 PM
You can use a Edlebrock with the marine accelerator pump and some sealing.
64 Commander 2 dr.
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
62 GT Hawk 4 speed
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
Stude4x4
01-27-2007, 10:50 PM
Hey Spence, Come check out www.racingstudebakers.com/stl-web/bulletin/bb/index.php theres lots of good info there also on Hi-perf Studes.
Jake
-Home of John Studebaker-
http://community.webshots.com/user/Stude4x4
http://varozza4x4.com
http://thumb14.webshots.net/t/57/157/5/81/52/505758152RLAddy_th.jpghttp://thumb14.webshots.net/t/50/150/3/37/35/506033735XtAfdS_th.jpg
01-27-2007, 11:22 PM
Greetings, hurricane,
There have been successful Paxton/WCFB installations in the distant past.
One thing to remember is 4-bbl carburetors are flow-rated at around 1" of vacuum. Add five pounds of boost and a 400cfm WCFB will flow all the air a stock 289" can ingest. The '57-58 Golden Hawks made do with a 2-bbl Stromberg of a much smaller CFM rating.
If the combination is a 300" with ported heads, big valves, longer duration camshaft, then a 600CFM Carter or Edelbrock would recommended.
thnx, jv.
