I purchased a 63 GT hawk about 4 years ago, and was able to buy it because the owner was never able to resolve heating problems. It has a 289 2v and automatic. I wrote to TW and Bob Palma Suggested several things.
So far I have; Re-cored the rad to a new 3 row unit,
removed frost plugs and cleaned block (not really corroded),
new thermostat 180 deg ,
new exhaust system (2in) including R3 headers and new manifold valve
Checked initial timing, petronix ignition modual.
new block heat sender, and cleaned terminals to the heat guage. Checked initial timing as per service manual.
Did not check distributor advance as I don'tknow how or have specks.
It doesn't seem to be heating any more, but to me the problem does not seem to be solved as it seems to labor or be just lazy in the way it runs, and maybe part of the initial heating problem was rooted in some other problem. Compression is between 105 and 115. Don' know if it burns oil, untill I get all engine leaks fixed. So I checked cam lift and timimg per service manual. Lift at the valve measured by a caliper o0n top of the valve was .34 to .35 in. My measurement could be off by .01 or so Book says .36. The service manual tells how to check cam timing and calls for about 12 deg advanced, but mine showed that it started at about 4 deg, just about the mark to do ign timing. Since I was doing main seal for oil leak, I checked the timing dots on the gears to make sure they were correct. I then removed the crank timing gear and advanced the cam by one tooth. As I recall that brought my cam advance to about 23 or so advanced, ( r1 calls for 18 or so). So advance is closer to what it should be ( although the closing of the valves will be maybe a bit early) So it starts and idles better, and has a more lively exhaust sound. I then took ti out and ran it and at speed (I use this term relatine to our 35 year old horse) the results are the same.
Top RPM is 3600 in first gear, on the flat, same for second. 0 to 60 was maybe 18 seconds. 70 MPH was at about 2700, but it feels as though it is beeing really pushed to get this. I didn't do a top speed but I think 90 would be it.
Any one have a HP-Torque-RPM chart for this engine?
Does any one make a higher lift cam? Would it do any good, or is the intake-Exhaust too restrictive?
Is this normal for a 63 Hawk? I have rode in larks, and they seem to be much more responsive. I have driven other 2v carbed engines, and they all seem to go past 4000 fairly willingly. I think the old dodge ('61) 361 had about the same carb, and it reved much easier.
Right now it is in the shop as the trans started jumping out of
drive. Could the trans been dragging the engine down?
Anyway any suggestions would be appreciated. Last resort is I do have a 360 Dodge engine I took out of a Pickup to install a diesel.....(please start throwing rocks-----) I also have 2 BBcaev ingine with the rods out, bu they would be even worse than the stude, becouse at least it runs.
Thanks for bearing with me Sincerely David
