View Full Version : Back Glass
Rob
01-24-2007, 11:08 PM
On my 51` it has a 2 piece back glass but I want a solid glass(I think they look better) How hard will it be to find one?
Rob
spookys
01-26-2007, 11:41 AM
Rob,
you might have to have one custom made, but check with Vic Phillips of Phillips Classic Glass, he advertises in the TW but here is his email and P# classicglass@semo.net 873-785-1927
01-26-2007, 01:47 PM
Rob, do you have a business coupe? Reason I ask is that it's the only 51 that had a two-piece rear window.
As has been suggested (assuming this IS a Q-body), custom fab will be the ONLY way you have a glass made, shy of using plastic. [}:)]
Miscreant adrift in
the BerStuda Triangle
KGlowacky
01-26-2007, 04:57 PM
Here is a glass company that can probally make you one. I have seen his work and it is good. They have the correct tint if you have tinted windows. Will be doing all my new glass for my 56 wagon. Reasonable, I think. Good Luck Vintage Glass, 480 Pike park Drive,Suite E, Lawrenceville,Ga. 30045 Greg Roberts 770-900-6363. www.vintageglass.com ,E-mail- vintageglass@hotmail.com
Rob
01-26-2007, 07:23 PM
My car is a 51` State Sedan. I have a 50` Land Cruiser that has a two piece rear glass, and I just assumed that my 51` would to.
Rob
1950 Land Cruiser
1951 Commander State Sedan
ma1951
01-28-2007, 12:06 PM
I HAVE SEEN AND REMOVED FROM CAR BOTH ONE AND TWO PIECE BACK GLASSES. I BELIEVE THE ONLY DIFFERNCE IS THE METAL STRIP IN THE CENTER THAT IS WELDED TO THE MAIN BODY. YOU PROBABLY COULD CUT THIS PART FROM A PARTS CAR AND WELD INTO A 1 PIECE BACK GLASS TYPE CAR PROVIDED YOU WERE ACCURATE WITH YOUR DIMENSIONS CENTERING UP METAL POST BEFORE WELDING.
01-29-2007, 06:03 PM
Your 51 will have a one-piece rear window.:)
Miscreant adrift in
